How to Paint Realistic Grass in 3 Steps
Use High-quality Assets to Render Photorealistic Lawn in 3 Steps
A photorealistic lawn is critical to architectural and landscape visualization. Today, we want to introduce you an easy way to create lifelike grass with only three steps.
Render: Pathompong Lohavijarn, Golffy Arch | Architect: Belmont Freeman Architects
Step 01: Set a Lawn Material
First, choose a woodland material and apply it onto the model surface.
Stretch its UV to get a dense look.
Step 02: Paint Grass Models
Then, choose a grass model to fill the lawn with the 'Scatter' tool.
Repeat the step on another kind of higher, greener grass.
Remove a bit of the lawn randomly with the Eraser tool.
You can also add some scattered fallen leaves.
Step 03: Add Decorative Plants
Place some shrubs along the edge.
And intersperse some in the middle.
A tall tree at the foreground will make the scene look more layered.
That's it! You've just brought a lawn to life. D5 Asset Library in D5 Render makes it super easy to create 3d visualization. So, make sure to give this amazing real-time rendering software a try!
