How to set realistic background for render in 1 minute
Home
Blog
Artist: Tomorrow | Rendered with D5 Render
For architectural visualization, environment setting is critical because it directly tells your audiences the story of the architecture. It includes sky, weather, surrounding landscape, backdrop context and many other elements. How they interact can greatly impact the realism and quality of the final render. For example, the glass facade usually reflects the surroundings. You don't need to spend hours placing buildings around to have such a beautiful reflection. All you need is a backdrop plane from D5 Asset Library.
What's backdrop plane and why
Backdrop plane is like an entire context in one polygon. They can decorate the distant skyline, add nice glass reflections and adorn the view outside the window.
With D5 Render 2.4, new backdrop planes are updated for urban, mountainous, and wooded contexts. You can use them for architectural and interior design.
Drag and drop a backdrop plane from D5 Asset Library into the scene. With a few tweaks in a minute, you can get a stunning background for your render, which is very convenient.
Backdrop plane for architecture | Artist: Light | Rendered with D5 Render
How to use it
After setting the foreground, go to D5 Model Library > Landscapes. Select the backdrop plane you need and import it into the scene. Scale it properly to cover the skyline. Done! That's all you need to do.
Conclusion: Speed Up Your Renders with Backdrop Planes
So, setting a realistic scene no longer means hours of modeling. Just grab a backdrop plane, drop it in, and tweak it. In under a minute, your project gets that stunning, story-rich context. Ready to transform your renders? Go try these new backdrop planes in D5 Render today
너는 또한 좋아할지도 모른다
최초의 3D 시각화 협업 플랫폼
D5 렌더를 통한 KPF의 혁신적인 도약
